Results 1 to 10 of 13
Thread: Cloudy ,Cloudy,Cloudy... for a week now.
    Virginia Beach, Virginia, USA.
    Default Re: Cloudy ,Cloudy,Cloudy... for a week now.
    Thanks again for all of your advice and instruction. I am a Flight Attendant so I am away for days at a time with no one to care for the pool . I bought a floating despenser to keep the tri tabs clorinating the pool and the pump running on low when I am away and my water is Sparkling.... I use the BBB method and I am pleased .
    Thanks for the update. If you are going to use the trichlor pucks, you'll need to keep an eye on your CYA as the pucks will continue to add CYA. Every week or two, test it and when it gets to about 50, you'll need to discontinue using them. They are also very acidic, so you'll also need to watch your pH to make sure it doesn't get too low.
    Understood, thank you. I will nwatch the numbers and I have stoped using them for a week noe and things are looking good. I only use 1 gallon bleach every 10 days and things are going fine
  1. Replies: 0
    Last Post: 05-20-2013, 08:00 PM
  2. From cloudy green to cloudy blue
    By Dydylynn in forum Dealing with Algae & Slime
    Last Post: 06-10-2012, 06:09 PM
  3. Pool still cloudy white. Been a week today... This stinks.
    By Lawrosa in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-14-2011, 12:13 PM
  4. Clear->cloudy->green in a week, alkalinity problem?
    By PoolInMich in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-06-2006, 09:25 PM
  5. Still cloudy--
    By Piney in forum Dealing with Algae & Slime
    Last Post: 07-19-2006, 08:59 PM
