Ok. In the meantime until you get a CYA reading, go ahead and keep adding doses of bleach to get the chlorine up to 12ppm. I'm assuming your volume to be around 13,500. So, each quart of 6% bleach will add about 1ppm. As often as you can test and add bleach, the better. Until you are able to get the good kit, go to Walmart and buy a cheap OTO/Phenol red kit (yellow and red drops.) It will only read chlorine levels to 5 but you can force it to go higher with a dilution method described here:
Testing Without a Good Kit
Once we know the CYA, we'll tweak the recommendation for the shock level if needed.
