Results 1 to 10 of 12
Thread: NEWBIE - How to make fresh water ready to swim?
    Default Re: NEWBIE - How to make fresh water ready to swim?
    DCR is right that without cya you'll have a hard time keeping a chlorine reading. Until your cya has a time to dissolve, you'll probably need to test your water and add bleach morning and night. Actually, it is highly unlikely that cya will be dissolved in two days. More like a week. Don't test for it, add more or backwash for at least that long. Also, I don't think you have to run your pump non-stop during this time. Whenever I add cya in the spring, I stay with my normal pump run times and have never had a problem.
    Webb City, MO, USA.
    Quote Originally Posted by Watermom
    I was pretty sure I read on this forum that you should run your pump non-stop when adding CYA, and I believe the instructions on CYA says two days non-stop.
    Mandeville, LA, USA.
    Quote Originally Posted by DCR
    I'm sure that running your pump non-stop would help the CYA to dissolve faster, but to what end? If you add it through the skimmer and run your pump for "normal" periods, it will just be stuck in the filter a bit longer. I can't imagine what harm it would do there.
    Mesa, AZ
    Since CYA is an acid, before you turn off the pump make sure you know where the undissolved CYA is going to collect and whether that location is suitable for several hours of exposure to an acidic environment.
    Quote Originally Posted by cwstnsko
    The pH of a saturated CYA solotion is 4.8 so it is mildly acidic. IMHO, I don't think it will cause much harm.
    http://www.intox.org/databank/docume...acd/cie286.htm
    By comparison, Trichlor has a pH of just over 2 , vinegar is just under 3, and unpolluted rain is about 5.6.
  1. Fresh fill with city water - start with bleach or dichlor?
    By Mm_putnam in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-27-2013, 02:22 PM
  2. How Much FC To Make Water Potable?
    By Darkside in forum The China Shop
    Last Post: 12-03-2012, 04:27 PM
  3. Tiny microbubbles make water look cloudy
    By cygnusecks in forum Pool Equipment & Operations
    Last Post: 08-31-2006, 09:16 PM
  4. Please help! Pool newbie ready to give up!
    By catherineb1121 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-19-2006, 07:03 AM
  5. Help! Pool newbie getting ready to quit!
    By catherineb1121 in forum Pool Equipment & Operations
    Last Post: 06-18-2006, 10:34 PM
