Results 11 to 14 of 14
Thread: pump running 24/7 or what?
    Scottsdale, Arizona
    Default Re: pump running 24/7 or what?
    yes, the intermatic timers have little 'on'/'off' pins you screw on to set the run cycles. My electricity is a LOT cheaper from 9pm to 9am so I run 2 cycles first from 9pm to 12:30am and the second from 6am to 9am .
    No runs during the day and I have no problems.
    Jun 2011
    Franklin, TN
    Ah, the ol' timer. That was too obvious
    Is it difficult to install/wire them? My pump is hardwired to a breaker box. Only have experience with the little indoor plug-in timers.
    Is this one I found on Amazon what I need? http://www.amazon.com/Intermatic-T10...dp/B00002N5FN/
    SalemCastles Guest
    Scottsdale, Arizona
    Quote Originally Posted by anixon7 View Post
    That is the one I use. You can buy extra pins at Home Depot for multiple run cycles... I can't advise on the ease of install. I'm not allowed to change a light bulb without calling the city first to have the grid powered down ... me and electricity = trouble.
  1. Cost of running a pump 24/7
    By Guppy in forum Pool Equipment & Operations
    Last Post: 05-31-2012, 07:37 PM
  2. whisperflo pump running hot
    By klewando in forum Pool Equipment & Operations
    Last Post: 07-14-2011, 10:29 AM
  3. Running pump at night?
    By Cold Drink in forum Pool Equipment & Operations
    Last Post: 08-07-2007, 06:59 PM
  4. running pump
    By nicker in forum Above-Ground Pool Construction & Repair
    Last Post: 07-28-2006, 06:57 PM
  5. Hayward pump running hot
    By chipholder in forum Pool Equipment & Operations
    Last Post: 06-09-2006, 11:02 AM
