Closed Thread
Results 1 to 3 of 3
Thread: deck gounding
    Default deck gounding
    I am having a pool repoured. The deck is already in place. When they pour the pool, does it have to be tied into the deck with steel? It wasn't the first time and I see no rebar connecting it for the repour either.
    MarkC is offline Registered+ Weir Watcher MarkC 1 star
    Default Re: deck gounding
    The pool shell is usually not physically connected to the decking. In my pool they used roofing shingles on the bond beam to keep the deck from bonding to the bond beam.
    Indiana.
    You don't need a physical connection, but you need an electrical connection. If you require an inspection, you should get your inspector involved right now. The rebar or mesh in the pool shell needs to be electrically bonded to the rebar or mesh in the deck. Refer to the 2005 National Electrical Code, Article 680.
Closed Thread
  1. Brass deck jets versus Jandy deck jets
    By pumpkineater59 in forum Pool Equipment & Operations
    Last Post: 04-13-2012, 12:58 AM
  2. in deck or on deck slide and diving board
    By bszaronos in forum Pool Equipment & Operations
    Last Post: 03-16-2012, 12:52 AM
  3. Looking for AG deck ideas.
    By FastCougar in forum Above-Ground Pool Construction & Repair
    Last Post: 03-08-2012, 01:22 PM
  4. Pool Deck
    By kanane in forum Above-Ground Pool Construction & Repair
    Last Post: 05-02-2007, 02:44 PM
  5. moss on a carpet covered deck (factory pool deck)
    By JETTA in forum Above-Ground Pool Construction & Repair
    Last Post: 09-08-2006, 08:56 PM
