Results 1 to 3 of 3
Thread: low amps cell
    Jun 2011
    Default low amps cell
    I have a pool pilot digital system i got with the pool in my house i just bought. I have put about 9 bags of salt in the pool, it is a 12,000gal. That should have it to around 3200ppm. The system is now saying Low Amps-Cell? I had around 9 volts, 1 amp, and after i cleaned the cell i get around 16 volts 1.1amp. Any ideas what is going wrong?
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: low amps cell
    First step is to post a full set of test results including salt, CYA, CH, and TA.\
    Also, just to check, do you have the control unit set to the correct size cell?
    Finally , how old is the cell?
  1. AutoPilot Dig 220 Low Amps-Cell?/Check Clean Cell
    By tthurman in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-01-2014, 07:41 PM
  2. Autopilot Digital 220 - low amps--cell?
    By annm27707 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-07-2013, 12:43 AM
  3. Pool Pilot Low Amps Cell 0V 0.6A
    By vgg659 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-22-2011, 01:07 PM
  4. Pool Pilot "Low Amps Cell" (No chlorine)
    By scoobiedoob in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-05-2007, 02:53 PM
  5. How many amps for the pool area?
    By induce in forum In-Ground Pool Construction and Repair
    Last Post: 10-05-2006, 01:28 PM
