Thread: Hi First time to the forum. I do have an issue with my Zodiac LM3 15
    Jun 2011
    Default Hi First time to the forum. I do have an issue with my Zodiac LM3 15
    Installed new in 07. Now I am not getting enough chlorine output. I am wondering if anyone knows what voltages I should be seeing at the cell. The best I get now is -3.7 on the red wire. 14.06 on the black wire and 2.01 on the blue wire. This was on super chlorinate. The 3rd and 4th led are sometimes lit. The fifth never. Thanks.
    Default Re: Hi First time to the forum. I do have an issue with my Zodiac LM3 15
    Hi Honda,
    Sorry, but this one is totally not my department. But, fortunately, there are many members on the forum who will hopefully know about your cell. Unfortunately, most of those people will not be able to view your post until your registration is totally completed and your post is moved out into the SWCG section of the forum. So, sit tight for a bit and hopefully help is just around the corner!
    Welcome to the Pool Forum!
    Jun 2011
    Have you checked your salt level? The other possibility is that the cell needs to be replaced. Lifespan is usually around five years I think (depends on seasonal use, full time use etc.). I was having problems producing chlorine on my DuoClear unit last year (turned out to be a looming algae bloom that was consuming all my free chlorine) and when the Zodiac tech was at my house, he said if all lights could light up, the unit was fine and it was something else. If all lights couldn't light up there was a problem with unit or cell. In your case, since you can't get all lights lit up, it may be the unit/cell. Still I would check salt level of the water before I did anything else.
    Jun 2011
    Thanks for the input. I think it is the power board along with the older cell. I just bought a Hayward off Ebay. 675.00 Seemed like a good price and I like the fact it has a box to protect it from the elements.
  1. Long time forum reader
    By steve52 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-29-2012, 02:27 PM
  2. Zodiac-Clearwater- Avoid them!
    By vicar8 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 03-28-2011, 08:30 PM
  3. Clearwater Zodiac LM3-24 will not SuperChlorinate
    By jasondaniell in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-08-2010, 11:30 AM
  4. Zodiac Duo Clear
    By Sumo1 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-16-2007, 04:17 PM
  5. Zodiac LM2/LM3 SWG
    By caustik in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-29-2006, 01:11 PM
