Results 1 to 10 of 10
Thread: leveling ground for pool
    Jun 2011
    Default Re: leveling ground for pool
    chimed in because it sounded a little like you were going to build the pool on sand - that could be disastrous.
    nope, he's just getting the ground level before we put the sand in .. thanks BigDave!
    Jun 2011
    thanks so much stonedbeetle (gotta love that nic) & cramar!!! just now saw your posts ... exactly what i was looking for
    Building up is tricky, digging down is easy. Sand is only for the very top, needs to be contained, and should be leveled wet, not dry, so it compacts. Renting a compactor for the site is a good idea, too. There's the jumping-jack type and the lawnmower type. Both work well.
  1. Starting from scratch - leveling ground
    By tebbert in forum Above-Ground Pool Construction & Repair
    Last Post: 08-07-2012, 11:40 PM
  2. Doing some home work on Intex Ultra Frame - Leveling the ground
    By nazran in forum Intex-type Pool Setup & Operations
    Last Post: 07-29-2012, 12:37 AM
  3. need help leveling
    By tleigh0212 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-10-2011, 08:09 PM
  4. Leveling land with a roto tiller for a 14 ft pool.
    By ahutchins9 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-09-2011, 02:08 PM
  5. leveling and heating intex pool
    By savannah in forum Above-Ground Pool Construction & Repair
    Last Post: 04-11-2006, 12:06 PM
