Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 32 of 32
Thread: Cloudy Water
  1. #31
    Default Re: Cloudy Water
    You could always use Poconos's plastic sheet method and COMPLETELY replace the water in your pool, so you can swim in it this summer. I'll ask him to post the link to his description.
    Thanks. I found his post on how to replace the water with the plastic sheet.
    adding the bleach the last time i posted on 5/20... shock to 25 ppm.. has helped as the water is almost clear today. this morning the cya is still 90, ph 7.5, ta 180, chlorine 6.0. thanks for all the advise. i did and do appreciate any and all help you give. your forum is very helpful
  1. Cloudy Water
    By PoolConfusion in forum Dealing with Algae & Slime
    Last Post: 07-23-2012, 07:51 PM
  2. Cloudy Water
    By joserq in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-09-2012, 12:01 PM
  3. Cloudy Water
    By ComeShareACupofTea in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-06-2011, 10:49 PM
  4. CLoudy Water
    By Sunshine427 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2008, 02:57 PM
  5. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 08:04 PM
