First, you need to get your pH over 6.9 to avoid damaging your liner. Add on box of Borax, running the filter and test again in 1 hour. Repeat until pH is in the 7's.
You'll need to add bleach to clear the water. I'm guessing about 5 gallons of 6% bleach for now.
Then you should post a set of test values, including:
FC, CC or TC, pH, T/A, CYA and CH.
Also what kind of pump and filter you have and, if you know that gallonage (I'm ballparking at 20,000 gallons)
Check out our sister site, PoolSolutions.com. We'll guide you through it if it's not clear.
And you'll need a good test kit. Check it out there, too.
