Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
New here with my readings
FAQ
register
Reply to Thread
Results 1 to 8 of 8
Thread:
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Hybrid Mode
Switch to Threaded Mode
01:47 PM
#1
Watermom
View Profile
View Forum Posts
SuperMod Emeritus
Quark Inspector
Re: New here with my readings
She might, but she can adjust it then if it does.
Reply to Thread
Quick Navigation
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Equipment & Operations
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
Phenol red indicator question
New to pool
first readings!
By PBLsQuad450 in forum Using Chlorine and Chlorinating Chemicals
15
Last Post:
06-06-2010,
09:26 PM
High Chlorine readings - how do they impact other readings
By Charlie in forum DPD-FAS based testing
15
Last Post:
02-06-2009,
10:41 PM
1st Readings of the season :)
By ellenicol in forum Using Chlorine and Chlorinating Chemicals
3
Last Post:
05-29-2008,
08:37 PM
Day 5 readings...
By steveinaz in forum Testing and Adjusting Pool Water Chemistry
0
Last Post:
03-09-2007,
09:42 PM
Wierd PH readings...
By poolmom06 in forum Testing and Adjusting Pool Water Chemistry
4
Last Post:
07-26-2006,
01:24 PM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
