Results 1 to 10 of 42
Thread: Need help with starting chlorine after drain/refill
    Jun 2011
    Massachusetts
    Default Re: Need help with starting chlorine after drain/refill
    I did bleach it last year but then put it back in the pool to use for the remainder of the summer once we cleared the pink algae. I am in no rush to put the ladder in - would rather wait and be sure than create another problem.
    So, I did not use polyquat on my troubled water but spoke with Ben last night because my new fresh water ( after I added the bleach we talked about) tested a CC of 5 - which had me in tears. We discussed a plan to move forward which included polyquat because the man who brought the water suggested I test for metals before adding chlorine because he had seen some pools that he had filled go green after adding the bleach. Ben suggested polyquat to prevent that from happening since he figured the water man must know his water.
    I haven't added it yet because I only have a FC this morning of 0.5. ( my cc is still 5.5) I added 3 lbs of CYA by the skimmer, and also put a puck in this morning - but I am assuming this will only bring the FC up a little bit. So, what should I do now? I had asked Ben if I should try to get the FC levels up by pouring in bleach but he said not to lest I turn it green. I think he wanted to bindup the metals with the poly first. But my sense was he just wanted me to run it at the low swimming doses for now and see what happened. So, should I add a little bleach first then a little polyquat? add polyquat then bleach? My pool is not green at all - should I scrap the polyquat? Can i add bleach with the puck in the skimmer? ( I know that is a basic question - sorry - I have no idea how to manage a chlorine pool)
    The bottle of poly offers 2 doses - one for freshly filled pools ( 8-11 oz) and one for maintenance ( 2-4 oz) I could always just dose low to start, protect the pool from oxidizing metals and different colors and then I am free to raise the chlorine levels if I need to.
    Sorry for all the questions and confusion. My ph is fine btw 7.6 and 7.8. alk 70. so not doing a lot on those ends. I went to Ben about my CC because it is just too complicated to post here. He had me check my reagents and we plan to watch the numbers for a bit. Apparently we are in unchartered territory - again. aciam.
    + Add the polyquat right away, and keep doing so at 1.5x maintenance doses. Get it in RIGHT AWAY; we don't want your pool to turn green, while the chlorine is low!!!!!!!!
    + Add the CYA
    + Run your trichlor tabs, and gradually increase them to gradually bring the chlorine level up, over a week's time.
    + Don't use bleach before then.
    + Use borax if the pH goes below 7.0
    Ben
    Jun 2011
    Massachusetts
    I understand. It is hard form me too because I don't always know what to do. I was hoping to still be able to ask the basic questions here through the forum if that's OK. And I figured you all worked together. The last time I had run into trouble you all sent me to him so I figured I would be proactive this time is all.
    Like for example just now I tested : FC is up to 1.5 and CC down to 3.5 with no bleach smell for the first time since yesterday. My alkalinity is still 70 but my pH dropped to 6.8-7. ( probably from all the cya and puck this morning) I think I should add Borax? is that right? just can't figure out how much though. Is that OK to ask?
    He didn't give me all the specific nitty gritty of how to proceed - like in terms of the poly and the FC dropping so that information is truly valuable for me. I hope I can still ask that here since I think you all are probably more available and more accustomed to answering those types of questions. thanks. aciam
    Jun 2011
    Massachusetts
    Thanks Ben!
    +3 lbs of CYA added at 830 am
    +1 trichlor tab put in skimmer at same time with improved readings at noon FC=1.5 CC =3.5 no bleach smell
    +I will add polyquat now in the dose of 4-6 oz? and then how often do you want me to keep doing so? please confirm both
    +pH at noon down to 6.8-7.0 - have Borax but not sure of dose - is there a reference or can you give dose to me?
    + will not add any more bleach just pucks to inc chlorine until you give me permission
    Let me know your thoughts about the ladder whenever you have a chance. thanks. aciam.
    Jun 2011
    Massachusetts
    Hi Ben - just a quick update.
    Noon today - added 4 oz polyquat
    2pm added second trichlor puck to skimmer to maintain/inc FC after polyquat addition
    3pm added app 18 oz borax to skimmer due to pH of 6.8-7
    8PM testing
    OTO TC =2 pH = 7.2
    DPD FC = 2 pH = 7.2
    FAS-DPD FC = 2 CC=4 pH 7.2 alk 70
    I am adding nothing at this time.
    I will retest in am and add more borax if needed. Let me know what I should be shooting for in terms of FC levels so I can add pucks as needed. And when/if I should re dose polyquat. Thanks! aciam
    Looks like you are doing well, and just need to 'stay the course'.
    Ben
    Jun 2011
    Massachusetts
    Thanks Ben!
    Here are this morning's number:
    OTO TC=3 pH 7.2
    DPD FC=3 pH 7.2
    FAS-DPD FC 3-3.5 CC 3.5 pH 7.2 alk 60-70
    remainder of 2 pucks of trichlor in skimmer
    I decided to add just a tiny bit more borax but nothing else. Let me know if I should be messing with the alkalinity at all. We are off to a family function. Will retest tonight.
    Questions: What do you want me to be aiming for in terms of FC?
    Do you want me to redose polyquat once a week?
    Is there any threat to re introducing my pink algae ladder into the pool? or should I just invest in a new one?
    Thank you. Have a good Sunday. aciam
  1. High CYA, drain 1/3 refill?
    By fatstogie in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-07-2012, 06:06 PM
  2. Starting with SWCG - no chlorine level
    By brefri in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-15-2012, 03:41 PM
  3. Drain and refill 33,000 gallon gunite pool
    By bugsy0329 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-25-2011, 04:06 PM
  4. Drain AG and refill?
    By Islander2C in forum Above-Ground Pool Construction & Repair
    Last Post: 05-18-2007, 08:02 AM
  5. drain refill and think it's good - your thoughts?
    By west1745 in forum DPD-FAS based testing
    Last Post: 07-25-2006, 11:49 AM
