Thread: Newbie - has question or more specifically needs confirmation - pool install is now!
    Jun 2011
    Northern VA
    Default Newbie - has question or more specifically needs confirmation - pool install is now!
    I tried to post in the chemical forum but it would not let me post, I have no idea where this should be but here it goes:
    I have read on here that vinyl lined pools do not require calcium but the pool store guy said that they were sending it to be added to the water "to keep things from rusting". Is that things on the exterior for when the water splashes out. The pool is a swim and play, Islamorada model and it is a steel frame (walls) that have been coated and sealed. Should I have this chemical put in the pool or do I tell them no? The only other information I have on the chemicals is that they are all made by OREQ. Thank you so much for any and all assistance!!
    Default Re: Newbie - has question or more specifically needs confirmation - pool install is n
    Tell them NO. You do NOT need calcium in a vinyl pool.
    Welcome to the forum, by the way and thank you for becoming a subscriber. We appreciate it. If you haven't already done so, read through a lot of the posts here on the forum and also read on our sister website www.poolsolutions.com. You will learn a lot about pool care. Then, come back here and ask any questions you may have. Hope you enjoy being a part of the forum!
  1. Need quick confirmation that I'm dealing with iron
    By jenmenke in forum Dealing with Algae & Slime
    Last Post: 07-30-2012, 06:24 PM
  2. Newbie Pool Question
    By carmendiva1922 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-24-2012, 08:36 PM
  3. AG Pool Install Question
    By glepage in forum Above-Ground Pool Construction & Repair
    Last Post: 05-26-2006, 09:04 PM
