Results 1 to 3 of 3
Thread: Chlorine Geni
    Jun 2011
    Delaware, USA
    Default Chlorine Geni
    I happened upon this website: http://www.thechlorinegeni.net/ while doing some research on Salt Water Chlorine Generators. The Chlorine Geni is a standalone chlorine generator versus an inline system and uses tap water instead of pool water and uses a lot less salt. More info available on their website, which has a few info videos on how the Chlorine Geni works. My question to you...once you've watch the info -- is do you think this would be a better investment than an inline system? The Chlorine Geni is near $3000 per unit, which is about double the price of an inline system for a in-ground pool my size -- 20' x 40'.
    Thanks in advance for your input.
    Dane
    Default Re: Chlorine Geni
    Stand alone chlorine generation is not new.
    http://www.thechlorinegeni.net/contact.html
    http://www.troublefreepool.com/the-c...t20541-40.html
    http://www.poolforum.com/pf2/showthr...-Chlorine-Geni
    http://www.bbb.org/greater-san-franc...inez-ca-370390
    However, the companies I know about that were making units that 20 years ago are no longer in business. One of the major issues has been that most of these units can malfunction and make chlorine gas.
    I hadn't heard anything about the chlorine geni unit, but I'd advise against it for the following reason:
    1) there's no technical data available, just flashy videos.
    2) the domain "thechlorinegeni.net" was registered in Sept 2008, so you are dealing with 2 1/2 year old company.
    3) the registration is a concealed registration, that make the company info unavailable. This is reasonable thing with personal domains, but I don't recommend doing business with companies that deliberately make it hard for you to find them.
    4) 5 year warranties offered by 2 year old companies are intrinsically deceptive.
    5) Essentially, they are being made in a garage:
    http://maps.google.com/maps?q=5031+B...22.073972&z=21
    Bottom line: there's not enough info for you to make an informed judgement about the units, but there is enough info for you to know that you will be an 'early adopter', and thus will be 'experimenting' with a product being developed and marketed by a new company.
    If you like being a guinea pig, go for it.
    Actually, since I wrote this in response to your email, I discovered that this is an OLD, grizzled system, that's been renamed several times. The risk of chlorine gas and difficulty of disposing of used brine characteristic to those units applies, but I can't tell you how well this unit handles those risks.
    jilted is offline Registered+ Thread Analyst jilted 0
    Jun 2011
    Louisiana
    I'm no expert on it, but their marketing on youtube ticked me off. They have tons of videos on there with misleading names so you end up watching their commercial inadvertently. That's enough reason for me to not buy from them!
    26,500g inground vinyl liner (new liner installed June 2013)
    Hayward 1.5 HP Super Pump - Hayward sand filter (sand changed in spring 2009)
    Compu Pool CPSC36 SWCG - Polaris 380 cleaner
  1. Chlorine tabs vs chlorine bleach generic
    By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2013, 10:28 AM
  2. Chlorine Geni
    By James in Sacramento in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-20-2012, 08:41 AM
  3. Chlorine Geni
    By pratzert in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-08-2010, 05:56 PM
  4. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
