Thread: Small pool - how much bleach?
    Default Small pool - how much bleach?
    How much 6% bleach do I need to raise 5500 gallons 1ppm. How do you figure this out?
    Thanks,
    Bruce
    Default Re: Small pool - how much bleach?
    Thanks, I downloaded the calculator.
    Bruce
    can't find mwsmith2 in "search" or "members list" for calculator. where else can i look?
    nc.
    Southeast N.C.
    Home of the Monster Bugs!!!
    Iowa
    Click here:
    http://home.earthlink.net/~mwsmith70...achCalc262.exe
    After you download it, you might want to go to "more calcs" in the upper left hand corner, click on "settings" and change the unit of measurement to "imperial". That let's you calculate in gallons.
    Oct 2004
    Sounds like I have the same size pool 15' AG...
    With thanks to this forum I have had crystal clear water so far this year by simple adding only bleach when needed.
    I havn't needed the calculator as I have just roughly adjust as needed but wondered if there is a calc for CL consumption. I do realize there are several variables making it a tough equation. Without using PUCKS I'm going thru on average a jug a week (5L). At a cost of under 2 bucks this is great but is this consumption normal for a average used 15' AG pool? I do add the bleach at night as advised and water temp is around 80 still. Just wondering if stabilzer is needed or should I stick with what works so far?
    Thanks again.
  1. Water problems in small, small pool
    By MikeFromMesa in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-10-2013, 03:53 PM
  2. New small kiddie pool.
    By chadgreen in forum Above-Ground Pool Construction & Repair
    Last Post: 07-28-2011, 11:54 PM
  3. Help with small pool
    By Stacie in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-18-2011, 08:20 PM
  4. Small pool
    By DONNIE in forum In-Ground Pool Construction and Repair
    Last Post: 07-08-2006, 09:13 AM
