Thread: Filter question
    Jun 2011
    Tennessee
    Unhappy Filter question
    Hi, Newbie here! My filter doesn't seem to be closing completely on the inside. When it's on filter, water is coming out of the waste/backwash pipe in the yard. It's seems like it isn't completely closing the valve of the inside when you switch it to pump. Not able to run the pump because the water is draining in the yard. Any ideas, suggestions? TYIA!
    Default Re: Filter question
    The simplest solution for the short term is to put a ball valve on your backwash connection and shut it when you are filtering, opening it to backwash or pump to waste. This may be all you need if all the other functions are running OK. Ball valves and the necessary fittings are available at pool stores and plumbing warehouses, and at Home Depot and Lowes. Easy short-term fix and you can do it today to prevent problems with your water.
    You probably have a damaged "spider gasket" in your multivalve, but it could also be the walls of the valve are damaged, or the springs are weak and damaged. Or, of course, that it's not assembled correctly. Sooner or later you should get this fixed.
  1. Sand Filter question.
    By Steve V in forum Pool Equipment & Operations
    Last Post: 05-30-2011, 09:25 PM
  2. Filter Question
    By edlentz in forum Above-Ground Pool Construction & Repair
    Last Post: 07-11-2009, 09:28 AM
  3. Question about AG DE Filter
    By vinnygnj in forum Pool Equipment & Operations
    Last Post: 06-08-2007, 02:45 PM
  4. Changing Sand in Filter and Random Filter Question
    By newbie2pools in forum Above-Ground Pool Construction & Repair
    Last Post: 07-24-2006, 02:38 PM
  5. Question about DE filter
    By Jlwine in forum Pool Equipment & Operations
    Last Post: 07-13-2006, 09:12 AM
