Results 1 to 10 of 58
Thread: SWG Operation - Lessons Learned
Threaded View
  1. #13
    Saint Cloud, FL
    Default Re: SWG Operation - Lessons Learned
    Quote Originally Posted by salinda
    Pat, I have very little scaling now--less since the swg was installed (not what I expected, but it's great!). My TA is only 90 according to the PS233. My system is well-balanced except for the Ca level and that is the same as last fall when I closed. The cell on my Clearwater is clear so I visibly check it often and I did do a muriatic acid soak on it at the beginning of this spring. Why would the salt level change "while removing scale?" I had to adjust my salt level this spring because we got soaked this winter in California and my water was very diluted, but now we won't see rain until next fall so the salt level should be fixed.
    Doesn't the salt water test use silver, which is expensive? That's probably why they don't have too many in stock.
    You might have had some scale on the salt sensor which is now clearing up.
    You should be able to get the salt water test kit easily. The chemical used is silver nitrate. This reacts with potassium dichromate indicator to give the red color of potassium nitrate.
    The reason they don't have too many in stock, is that the test kit at $25, lasts a LOT longer than the test strips at about $8.00, a third of the price. They would rather you buy test strips.
    Hope this helps.
    Pat
  1. swimming lessons
    By alisonquilts in forum General Interest
    Last Post: 06-10-2012, 12:17 AM
  2. Backflow / Waste Operation
    By BigDave in forum Pool Equipment & Operations
    Last Post: 06-25-2011, 01:00 AM
  3. Dynamic head, SWCG and 24/hr pump operation.
    By sailork in forum The China Shop
    Last Post: 07-11-2006, 03:44 PM
  4. Re: SWCG operation and lessons learned
    By PatL34 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-30-2006, 11:28 AM
  5. polaris 380 and pump operation?
    By buck1s in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-25-2006, 08:48 PM
