If my PH is steady at 7.4 and my water is balanced and clear should I add some Muriatic acid to maintain salt levels as part of the process? Should I bring the PH down to 7.2 or just leave it alone? I have not had any problems with low salt levels or anything for that matter. The pool is inground vinyl liner about 8000 gal. FC-10 / Ph-7.4 /TA-110 / CYA-60-70/ CH-250. Pump runs 12hrs a day with Aquarite set at 20%.
