Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 52 of 52
Thread: Inherited a pond, trying to turn it into a pool!
  1. #51
    May 2011
    Ronkonkoma, Long Island, NY
    Default Re: Inherited a pond, trying to turn it into a pool!
    I think I can finally claim victory - three nights in succession with no FC loss. CC tested today with a 25ml sample is 0.2ppm or less - one drop cleared the solution. The filter has run for three days straight without gaining more than a couple psi.
    So... I'll let the CL drop down to 6 or so, check and adjust pH, and then add some CYA. Back on page 1, when I thought I had 40k gallons, 6lb of CYA was recommended. Now that I know I'm actually around 20k gallons, I assume I should add about 3lb? I guess once I get all my levels within the ranges here: http://poolsolutions.com/gd/poolsolu...try-guide.html then I'm good to go?
  2. #52
    Awesome news -- finally!! Congrats!
    In a 20K gallon pool, 3 lbs. of stabilizer will add about 20ppm of CYA.
    Ranges:
    Chlorine --- based on your CYA level. See the Best Guess chart in my signature below. (If you let the cl dip too low, you'll risk an another algae bloom.)
    pH -- 7.2-7.8
    Alk -- 80-125
    CH -- not needed in a vinyl pool
    Stay in these ranges and yes, you'll be good to go! Test chlorine daily, pH once or twice a week, alk every 2 or 3 weeks.
    Enjoy your pool!
    (For reference, in your pool, each quart of 6% bleach will add about 0.8ppm of chlorine. Use that to help you determine how much bleach to add each evening when you test.)
  1. I've inherited a mosquito-breeding pool, and need to close it.
    By DewiMorgan in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-05-2011, 07:33 PM
  2. My pool looks like a pond !
    By crazimom in forum Dealing with Algae & Slime
    Last Post: 04-24-2007, 02:34 AM
  3. Inherited Pool Problem?
    By ariasc in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 08:18 PM
  4. Help pool is very green looks like a pond
    By sierrasmom in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-15-2006, 05:44 PM
  5. pool/pond building
    By Michaela521 in forum In-Ground Pool Construction and Repair
    Last Post: 05-04-2006, 11:50 PM
