Thread: Off the charts chlorine question
    Largo, Florida
    Default Re: Off the charts chlorine question
    I did the same thing (twice) about a month ago. I was really scratching my head for a few days!
    steveinaz is offline Lifetime Member Weir Watcher steveinaz 2 stars steveinaz 2 stars
    Southern Arizona
    Anytime I get suspicious readings, that are really over-the-top, I double check and/or replace my reagents.
    Jun 2011
    Louisville KY
    LOL – I bet that’s why my TA and CH tests indicate my pool water is concrete.
    Thanks for posting this JazzMan (take my blues away.....)
    Circa 1980 IG, VL, 36K Gal, DE, Chlorine
    May 2011
    I also have that basic question. Is it possible to generate too much chlorine with a SWCG?
    Yes, it is possible for the SWCG to generate too much chlorine, but there is a limit to how high it will go unless the pool isn't exposed to sunlight. When exposed to sunlight, the loss of chlorine is proportional to the amount of chlorine in the pool so when that loss equals the amount of chlorine coming from the SWCG, the chlorine level won't rise anymore.
    Usually, you'd see your FC level get too high if your SWCG percent on-time was set to handle sunny days and you get a long string of days of cloudy weather or if you decide to cover the pool with a mostly opaque cover. It's times like these that you would turn down your SWCG percent on-time.
  1. Chlorine question
    By waldreps in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-21-2012, 10:49 PM
  2. Chlorine Question
    By Jason R in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-19-2012, 10:25 PM
  3. Chlorine question
    By newbie2pools in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-26-2006, 09:29 AM
  4. Chlorine tab question
    By Waterdragon in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-25-2006, 08:34 AM
  5. Another chlorine question
    By Donna's Poolboy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-23-2006, 08:47 PM
