Results 1 to 10 of 66
Thread: Which SaltWater Chlorinator
    Jul 2006
    LA (Lower Alabama)
    Default Re: Which SaltWater Chlorinator
    Just my opinion, but I'd stay away from Autopilot. My Dig-60 died within 60 days of purchase and I got a refurbished power supply as a replacement. That one didn't last 30 days. Got another refurb. This one made it just past the warranty date (of a unit I bought brand new). If you bought a 1500.00 refrigerator/stove/a.c. unit and it died in 60 days, would you be happy with a refurb as a replacement? You will be if you buy an Autopilot!
    Ft Lauderdale, Fl
    Rollo,
    If I were you, I wouldn't be happy either!! I recommend calling the customer service manager and retelling your story. A new unit failing within the first 30 days, or even 60days should be replaced with a new unit, IMO.
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
    Jul 2006
    LA (Lower Alabama)
    Sean,
    Believe me, I've been through all of this with Autopilot customer service. Just got the standard "That's what our warranty states" and they were right. The warranty does in fact state:
    This limited warranty is for the replacement of defective parts. Manufacturer reserves the right to replace defective parts with new or refurbished parts at its sole discretion.
    So if the power supply dies in 1 day or 1 year, Autopilot can and does send out refurbs as replacements. I would have rather waited to have my BRAND NEW unit repaired than get someone else's problem. If anythig though, I've learned to read the warranty alot closer when buying a big ticket item.
    gwrace1 is offline Registered+ Thread Analyst gwrace1 0
    Dec 2005
    South Central Texas
    We are in our 3rd pool season with the Aquarite. The pool is open year round and is about 26000 gallons. I run the unit at about 40% and it keeps the chlorine level consistently at about 2-2.5 PPM. No water problems whatsoever and the pool has always been sparkling clear.
    Highly recommended.
    David
    33' Artesian Echo Canyon Ultra II round with 54" wall 26000 gallon capacity -- 1.5 HP 2 Speed Pump / Pentair 26" Sand Filter with Zeolite filter media
    Aquarite Salt Water Generator -- Complete aluminum deck with fence kit
    Aqualuminator with Fountain -- Solar Pool Lights
    Pool Pictures at the link below
    http://community.webshots.com/album/548241672nKeuyR
    I have an Aqualogic PS-8 and about 3 years in got a "No Cell Power" error. After much talking with others, it is apparent that the main board is bad. Cost to fix? $500-600. This doesn't include a new salt cell, just the main PCB.
    My question to Sean and others is: Since I already have the Aqua logic controller, how would I hook up a Autopilot (or other) system into this? The nice thing about the Aqualogic is that I just plug the cell in. The bad thing is one board controls everything, so if one things goes wrong, teh whole board has to be replaced.
    A local pool service guy is recommending switching over to the jandy Aquapure salt system (for $1300 plus install -no thanks), got me thinking of other alternative before i fix my Aqualogic.
    All functions other than salt are working fine
    Ft Lauderdale, Fl
    Answering just for the Pool Pilot, you do not want to interface the unit to communicate through the electronic control system as you will lose some of the key features of the Pool Pilot Digital. Specifically, Automatic Temperature Compensation and Salt amount display. What this means to you is that you will need to be as diligent in adjusting the Purifier % setting when temperatures change (the Pool Pilot does this for you).
    The Pool Pilot too, will have to be mounted as a separate system, as you mentioned the Intellichlor would need to be.
    This would be the same for anyone elses system, unless you go back with the replacment components from Goldline.
    Sean Assam
    So the PoolPilot would be a standalone system. I get that, but how would I get it to work? Right now, everything (Pump, salt, etc.) is controlled by the Aqualogic. If I went with a secondary, third party, salt system, how does salt system know when the pump is running etc.?
  1. Intex Saltwater Chlorinator issues
    By squeegeatc in forum --cleanup--
    Last Post: 05-20-2013, 07:19 AM
  2. switching to saltwater
    By mrsmatthews in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-08-2013, 05:36 PM
  3. Saltwater
    By recoughran in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-17-2012, 02:51 PM
  4. Love the Saltwater
    By wayfun in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-09-2011, 12:21 PM
  5. cya and saltwater chlorination
    By bizbad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-24-2006, 11:24 PM
