Thread: High Chlorine Level
    Jun 2011
    Default High Chlorine Level
    I opened my pool 3 weeks ago, and shock it as I normally do in the begining of the season. I took a sample to the pool store and my FC was 13, two weeks later it's still at 7 -8 PPM FC. I have an automatic chlorinator and it seems to be functioning properly. Is there a reason why I can't seem to lower the FC? I put in 3 pounds of chlorine nuetralizer which seemed to help lower it from 11 - 7. Any thoughts?
    Default Re: High Chlorine Level
    If you have an automatic chlorinator, I'm sure that's why it's sustaining a high level. Otherwise, there's no way a pool would hold that much chlorine for 2 weeks. What is your stabilizer level? With an auto chlorinator it can rise very high very quickly, so you might actually need to keep the chlorine at 7-8.
  1. Will high chlorine level harm my new SWCG?
    By Furbabyvet in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-02-2011, 06:56 PM
  2. Replies: 4
    Last Post: 04-25-2011, 06:55 PM
  3. High combined chlorine level won't budge
    By Carolina in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 10-13-2006, 09:54 PM
  4. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
  5. Is CYA test accurate with high chlorine level ?
    By JohnInSoCal in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-11-2006, 02:42 PM
