Results 1 to 10 of 11
Thread: Lengthening the life of a pool brush
    Apr 2011
    virginia
    Default Re: Lengthening the life of a pool brush
    my pool is a redheaded...
    Well, actually son, not stepchild! lol
    my 16 year old is responsible for the brush, I'm sure he abuses it...
    Lehigh Valley, PA
    I don't rinse my brushes after use but I do store them out of the sun. That's worked very well.
    Jun 2011
    Louisville KY
    Yes the sun. Forgot to mention that.
    When I strummed the bristles and they flew off I could only think of clogged pipes and locked rotors.
    Circa 1980 IG, VL, 36K Gal, DE, Chlorine
    THis is why you need to check your maintenance equipment periodically and replace it as needed. I just replaced my skimmer netand my corner brush last month.
    Largo, Florida
    When I bought my house I found the brush in a state similar to what you describe. I also found that the bristles had made their way through the skimmer (or drain) through the pump, through the filter, and into the insides of the salt cell. I'm assuming the previous owner must have run the pump with no filter or something but the point is you may want to clean your filter at least in case these nasties have been coming off the brush in the pool.
    Jun 2011
    Louisville KY
    waterbear - Yes I am eying my net right now.
    Hey kelemvor, I do like to open the filter and blast it with the hose. From years of experience I know a simple back wash doesn't do it well enough.
  1. The Wall WhaleXL Pool Brush
    By Redwolf in forum Pool Equipment & Operations
    Last Post: 06-27-2013, 02:39 PM
  2. Anyone try this pool brush?
    By Spensar in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-28-2008, 12:31 PM
  3. pool brush losing bristles again!!
    By vivian in forum Pool Cleaning: Manual or Automatic
    Last Post: 01-05-2007, 03:12 PM
  4. Cloudy Green Pool - Vacuum and Brush?
    By ccostan in forum Dealing with Algae & Slime
    Last Post: 05-30-2006, 06:36 PM
