Thread: Water under liner please help
    Jun 2011
    Columbus, Ohio
    Default Water under liner please help
    I have an inground pool. 3 feet and slants to 12 feet in deep end. When I took off winter cover my liner was floating. I put a pump behind liner and drained almost all of it. There is only a little more on the floor of deep end and I can't get it. Any advise what to use or can I just fill it and hope the water pushes it out?
    Default Re: Water under liner please help
    Welcome to the Forum!
    The water under the liner is either from a high water table in your area or spring thaws and rains which are having trouble draining through the soil. Adding more water to the pool will help push the ground water down and it should eventually recede on it's own. As the water leaves , you can use your pool brush to help keep wrinkles from forming - it's a slow process, but - if you're diligent, it should keep large wrinkles from forming.
  1. New liner, new water!
    By Gretchen in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-12-2011, 05:51 PM
  2. Wrinkled Liner and Water Behind Liner
    By rbposey in forum In-Ground Pool Construction and Repair
    Last Post: 09-26-2009, 05:40 PM
  3. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
  4. Water behind Liner
    By cschnurr in forum In-Ground Pool Construction and Repair
    Last Post: 09-04-2006, 10:20 AM
  5. Water Behind Liner
    By kdnulph in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-25-2006, 11:46 PM
