Re: Pool is clear finally, Now the liner is stained.
I unhooked the sand because I got a new cartridge for my old filter. I thought the cart filters better then the sand. I could easily hook it up again.
Do you then think its a filtration issue? I ran the cart overnight and all day a few days ago. The cart is new and has not raised in pressure. I did hose it off and just white water sprayed off it. I was thinking it was still a metals issue.
You say the sand with DE would be superior to the cart?
I was adding DE to the sand when the pool was cloudy from the previous posts. 1/2 cup raised pressure about 1 psi. The pressure would rise with it. Starts at 15 and goes to about 19. With out DE it does not rise. Just like the cart.
I guess I will try the sand and DE again.
I read about the sock but never used them. What will it catch?
Anything else to try?
12x18 vinyl AG 6.2K gal; Hayward equp: 16" sand filter (spring clean up) -- Xtream 100 sft cart (after clean up) -- Power Flo Matrix 1hp 2spd pump w/ AO Smith motor
