Thanks for the quick reply.
The box the pool came in says the pool volume is about 1800 gallons. The calculator on the kiddie pool page says it's about 2200. So I guess 2000ish?
The testing numbers I got are:
Cl: .5 (or possibly lower, was barely visible)
pH: The highest the kit shows is 8.2. It was at least that, if not higher.
When you say "you can chlorinate with a stabilized product," what does that mean, exactly? What is a "stabilized product?"
Are dichlor powder and stabilizer only available through pool supply places, or can I get those at hardware stores?
How do I test the stabilizer level? Did I buy the wrong test kit? Mine only seems to do chlorine and pH.
How do I know how much bleach to put in at a given time?
