Hi there, been lurking about for a couple of weeks and trying to learn what I can. Could use some help..
I bought a 12' diameter Intex pool and have set it up and filled it.
I have a Taylor K-1000 Basic test kit.
Following the "kiddie pool" guide, which my pool seems to qualify for, I put in about 6.5 cups of liquid bleach and about 2 cups of Borax yesterday. I ran the pump for a couple of hours and then tested, and the readings were both super high for chlorine and pH.
Today I tested again, not having added any other chemicals, and the chlorine reading seems to be almost non-existent. The pH reading is still at max (or higher if that is possible).
I can still smell some chlorine odor in the water, despite the reading being so low.
Where do I go from here? Do I put even more chlorine in, even though I put a lot in only yesterday? And do I need to get acid to lower the pH? I have been reading about it but I'm not sure exactly when to do what.
Thanks in advance for any help anyone can provide.
