Re: New China Shop Topic: How Accurate is the Pool Calculator?
waterbear
If you are talking about borax for raising pH then NO calculator is going to tell you how much to add. You will need to use a base demand test and use twice the weight of borax as you would soda ash for a specific pH rise as determined by the test. Not rocket science and a lot easier than adding a bit and waiting and testing and adding a bit more and waiting and testing until you 'creep up' on your target pH.
So The Pool Calculator's suggestions for how much Borax to add for a specified rise in pH are incorrect?
PS - love the academic debate. Keep it up!
My pool:
15x30 inground concrete pool w/spa in one corner overflowing into pool, all under screen enclosure
Hayward C1200 StarClear Plus Cartridge Filter
Jandy Laars LX400 propane heater w/120 gal above-ground tank
Jandy AquaLink RS OneTouch controller w/PDA remotes and computer control
JVAs control pool/spa switch and also allow drain opening
Hayward Navigator
