Results 1 to 10 of 15
Thread: New to bbb method and cya question
    May 2011
    Greenwell Springs La
    Default Re: New to bbb method and cya question
    The CYA test is pretty subjective and can be hard to read...the key is to try to keep your testing conditions (lighting, position relative to direct sun, etc) as consistent as you can. Whether it is 60 or 70, you need to get your chlorine up....you don't ever want it to go below 5 ppm, and in our climate you really need to keep it a tad higher just to give yourself some "wiggle" room.
    The pH definitely needs to come down a little. The TA is okay where it is, but will lower at the same time the pH lowers, if you add acid. Here's the step by step guide to lowering alk... http://www.poolsolutions.com/gd/lowe...p-by-step.html
    Thanks ! So I should keep my chlorine between 6-8 ?
    May 2011
    Okay I'll add more chlorine via the pool calculator at sundown . What should my target ph be ?
    Although anywhere between 7.2-7.8 is ok, I prefer 7.4-7.6.
    EDIT -- I just now saw that you are going to work to lower your alk. In that case, you'll want to drop your pH down to 7.0 and then aerate it back up. Be sure to read the link Jan posted for you above that explains the lowering alk process.
    May 2011
    what should my target alk be ?
  1. BBB method
    By CarterCrew in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-21-2012, 10:19 PM
  2. Question about using the bucket method to determine if I have a pool leak
    By JohnASmith in forum In-Ground Pool Construction and Repair
    Last Post: 04-14-2012, 08:12 AM
  3. Question about using titration method for testing cl levels
    By Armytiger in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-28-2011, 02:12 PM
  4. BBB Method - what is it??
    By lovedisney in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-01-2007, 10:21 AM
  5. The B method.....
    By matt4x4 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2006, 11:34 AM
