Thread: 2 Items Yellowing At Water Line in Steps Area and Sand discharging into Pool
    Jun 2011
    NNJ
    Default Re: 2 Items Yellowing At Water Line in Steps Area and Sand discharging into Pool
    Thanks for the quick reply!
    1. It only seems to spit out when turning the filter back on. I usually only rinse for less than a minute. As for air bubbles not too sure.
    2. U were right about the bellowing, coming out with some elbow grease and a brush.
    mbar's Avatar
    Ashland, PA
    If your pool is new, your filter is new too, meaning that your sand is new. New sand needs to be backwashed a lot, I mean a lot! It also will send very fine particles of sand back into the water (it happened to me). When you turn the filter off overnight, let the particles fall to the bottom. Then vacuum to waste, or the fine particles will just come back in. You can also put a skimmer sock on (or an old stocking) to catch the fine particles. As for the stains on the steps, you can also use a magic eraser. Let us know how you make out - and if you have any other questions.
    Northeast PA
  1. Replies: 1
    Last Post: 05-26-2013, 11:41 AM
  2. next steps for well water pool?
    By 33feet in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-14-2012, 02:55 PM
  3. Using sand to level an area for an Intex Metal Frame 15 x 48 pool
    By RedwingT in forum Intex-type Pool Setup & Operations
    Last Post: 07-13-2012, 10:29 PM
  4. algae dots above pool water line
    By Elizrix in forum Above-Ground Pool Construction & Repair
    Last Post: 06-16-2012, 01:01 PM
  5. black stain line around steps
    By hsdancer in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-26-2006, 11:00 AM
