Thread: 2 Items Yellowing At Water Line in Steps Area and Sand discharging into Pool
    Default Re: 2 Items Yellowing At Water Line in Steps Area and Sand discharging into Pool
    1. After you backwashed the filter, did you switch it to "rinse" mode for a few minutes before going back to "filter", to wash the remaining sand out of the lines? If not, that's probably your problem. If so, then you meay need to look for a cracked or broken lateral in the filter. Does the sand spit all the time, or just for a few seconds after turning on the pump? Any visible air coming out?
    2. Many things can cause staining, but I often have a yellowish tint to my stairs after the winter is over, but it's usually from leaves that have sat on the bottom of the pool and disintegrated over the winter . (My pool stays open all year, and my neighbor has a virtual forest in her backyard, so all her leaves blow into my pool over the winter. I usually wait until all the trees are bare before making an effort to get them all out, and usually don't get them all out until the water starts warming up.) Usually after a good 2-3 day shock, the yellowing goes away.
    If not leaves, then do you perhaps have metals in the water? Have you tried taking your chlorine up to shock level for a couple of days to see if that makes a difference?
    Jun 2011
    NNJ
    Thanks for the quick reply!
    1. It only seems to spit out when turning the filter back on. I usually only rinse for less than a minute. As for air bubbles not too sure.
    2. U were right about the bellowing, coming out with some elbow grease and a brush.
    mbar's Avatar
    Ashland, PA
    If your pool is new, your filter is new too, meaning that your sand is new. New sand needs to be backwashed a lot, I mean a lot! It also will send very fine particles of sand back into the water (it happened to me). When you turn the filter off overnight, let the particles fall to the bottom. Then vacuum to waste, or the fine particles will just come back in. You can also put a skimmer sock on (or an old stocking) to catch the fine particles. As for the stains on the steps, you can also use a magic eraser. Let us know how you make out - and if you have any other questions.
    Northeast PA
  1. Replies: 1
    Last Post: 05-26-2013, 11:41 AM
  2. next steps for well water pool?
    By 33feet in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-14-2012, 02:55 PM
  3. Using sand to level an area for an Intex Metal Frame 15 x 48 pool
    By RedwingT in forum Intex-type Pool Setup & Operations
    Last Post: 07-13-2012, 10:29 PM
  4. algae dots above pool water line
    By Elizrix in forum Above-Ground Pool Construction & Repair
    Last Post: 06-16-2012, 01:01 PM
  5. black stain line around steps
    By hsdancer in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-26-2006, 11:00 AM
