Re: Pool walls out of square
Figstimpy
the small numbers on those plans are ones i changed, this original one had a 12' shallow and we didnt want that. I only changed the info on the drawings to represent the dimensions.
The shallow end is 14X19X 4', the deep is 14'X14', with a 5'X8' section at 7'. The slopes coming in from the sides and end slope 3', and the slope from the shallow is 6'
I was referring to the table on sheet 1 titled Installation Data that shows the plan of the pool.
This shows the dimensions from the work points. If the walls are 7” out of square then some of those dimensions were not held.
For example, the table says from point B to point C is 10’-0” and from point B to point K is 31’-9”. If those measured dimensions are not held then you’d have an out of square situation. In other words line B-C is not parallel to line N-K.
I assumed the out of square problem is with the plan, since you mentioned the enclosure would not be square with the house. Are there also problems with the depth as well?
Circa 1980 IG, VL, 36K Gal, DE, Chlorine
