Re: Experiment: Homemade Sump Pump Filter to get rid of brown water
I agree with Carl. When you get the water as clear as you can, start to add the sequestering agent. Add it according to what the bottle says. After you add the sequestering agent, check the ph. Add some conditioner (stabilizer) according to the directions on the bottle, you need this so that the pool will hold chlorine in the sun. When the ph is between 7.0 & 7.2 you can start to add the bleach. Just add a little at a time until you get the bleach where you want it according to the "best guess chart" for chlorine. If you see stains or the water still has some discoloration, you can add some more sequestering agent. If you get most of the metals out using the homemade filter (great job!), you shouldn't need a lot of sequestering agent. Remember that high ph along with high chlorine levels will make any metals in the water fall out of solution. When this happens lower the ph and add some sequestering agent. It will lift any new stains, and keep them in solution. Use your filter whenever adding water to the pool. If you have any questions, please let us know. Happy swimming! Just so you know, you can swim in a pool with stains as long as the water is balanced.
Northeast PA
