Thread: Don't trust the pool store
    May 2011
    kentucky
    Smile Don't trust the pool store
    I had a liner change ,a sand change bought all from same place about 800.00 total installed then the told me after i filled pool up and tested water i needed 8 lbs of calcium booster (i have a vinyl pool) 4 lbs stabilizer 10 lbs of chlorine pucks then i found this site i have learned that i didn't need calcium booster due to vinyl pool the pucks add stabilizer and the 4 gallons of pool shock is just double strength bleach (12%) i bought a liner ,happy bottom, wall pad paid for install then the still wanted to get every $ i had in chemicals !!! It pays to do research thanks guys you have opened up a whole new world of pool care and allowed me to put my wallet up.... Again thanks will need help with test kit .. Again thanks lots!!!!
    May 2011
    Default Re: Don't trust the pool store
    Taylor K 2006 is highly recommended here
    Sadly, you were "Pool-Stored". It's happened to all of us, leaving us sadder, but wiser. The K2006, K2006c, and Leslies Chlorine FAS-DPD Service Test Kit are all great tools. All basically the same (the "C" has larger amounts of test chems, Leslies is a re-branded K2006).
    However, in their defense, they probably just read off the liturgy of recommendations provided by Biogard or someone else, without knowing, say, that calcium is USELESS in vinyl pools.
    Actually Carl, unless Taylor has rewritten the pool guide that comes with the K2006, it embeds a bunch of the pool industry bogus chemistry. It's one of the reasons I started the PS23x series of kits.
    Ben
  1. Pool Store selling "bleach", or the pool store blinked!
    By Spensar in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-02-2013, 11:01 PM
  2. Whom would you trust?
    By jeepers in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-17-2011, 01:08 AM
  3. percentage of hydrochloric acid, hardware store vs. pool store
    By dhanger in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-21-2011, 02:45 PM
  4. Trust your equipment...
    By steveinaz in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-30-2007, 11:24 AM
  5. Which test to trust on CYA
    By Phillbo in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-25-2006, 02:43 AM
