Results 11 to 13 of 13
Thread: Taylor 2006c arrived
    Default Re: Taylor 2006c arrived
    Quote Originally Posted by madwil View Post
    you shouldn't wait to do the pH test- get your sample (44ml, I think), add drops, read color
    not sure why it changes with time; how long did it take to change? 1-2 minutes, or 10 minutes?
    I'd say in five minutes it from low 7 to 8ish. I'd be curious to know why too
    Jun 2011
    Louisville KY
    Hey JW –a shout out from another K-2006 newbie. I did my first tests yesterday too.
    Yes that thing is intimidating but the folks here assure me it gets easier.
    If you haven’t read the guide, do so. But read it in a quiet place in a calm state of mind. It is pretty easy to read but it had a lot of details in it.
    Just for fun I’m going to learn how to use the SI slide rule. Getting down with my geeky side an all.
    Circa 1980 IG, VL, 36K Gal, DE, Chlorine
    The Taylor website has some excellent videos that show how to properly perform the different tests.
    CYA test should be done with back to sun or in open shade.
  1. Taylor 2006C test kit mess
    By PJM361 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-09-2012, 09:14 PM
  2. taylor- 2005 vs taylor-2006
    By axell in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 02-11-2012, 11:05 PM
  3. New test Kit arrived today. Here are the numbers!
    By GA Mark in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-22-2006, 09:48 PM
  4. Taylor Test kit 2006c
    By murtot in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-18-2006, 08:06 AM
  5. First Run, Kit arrived today
    By Condo Steve in forum DPD-FAS based testing
    Last Post: 05-24-2006, 11:03 PM
