Results 1 to 9 of 9
Thread: Please advise with levels
    Digger is offline Subscriber Thread Analyst Digger 0
    May 2010
    Milton, PA
    Default Re: Please advise with levels
    What should I do than? Cautiously add more stablizer, so I can maintain lower chlorine levels?
    May 2010
    Milton, PA
    I lost my notes from last year, I will have to reread some of the posts on here. I don't fully understand what levels are suppose to be? I was going by my Taylor testing book. And 1.5 TC and CC of .5 sounded good, I thought? Sounded like CYA could go up some? But, I know it is crucial to not get too much, because the way I remember it works against you, and you can't remove
    You are right --- you don't want too much CYA because it is hard to remove if you have too much. How long has it been since you added the stabilizer (CYA)?
    By the way, instead of making three posts within minutes of each other, you can just click on the edit button in the lower right of the post and then just add whatever you need to.
    Good levels:
    pH -- 7.2-7.8 but usually 7.4-7.6 is what I prefer
    TA (alk) -- 80-120
    CYA 35-50 (but different climates may have different needs here)
    Chlorine --- depends on what your CYA level is. See the "Best Guess Table" link in my signature below.
    May 2010
    Milton, PA
    Wink Re: Please advise with levels
    Thanks for the advice. Sorry, oops didn't know that with posting! Will try next time. I added CYA 2 nights ago with the sock method by the return. Wondering if I should try to add a little more, maybe just a scooper or so? Thanks!
    Do NOT add any more CYA at this point. Wait about a week and then retest and see what the level is. Your reported your reading as being 32 but we want to make sure it is all totally dissolved before adding more. Keep the chlorine between 3-6 all the time for now. When you retest the CYA next week, if it has gone up much, we'll tweak that recommendation, but for now, 3-6ppm should be your range for your chlorine.
  1. need advise of what to add
    By poolhelp101 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-16-2010, 12:09 AM
  2. seeking advise
    By poolpilot in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-27-2006, 09:09 PM
  3. Please Help / Advise
    By meajma in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-07-2006, 09:49 PM
