Thread: Air in sand filter
    Jun 2011
    Default Air in sand filter
    Hello,
    Recently when I open the "burp" valve on top of my sand filter there is a whole
    lot of air that needs to be purged. Even after releasing it the filter will fill up with air
    again in a few hours. Could it be a leak in the multivalve? I do not see anything obvious
    around the pump, pump basket, or piping.
    Thanks!
    Default Re: Air in sand filter
    It could possibly be a leak in the multivalve, but I would think that it wouldn't fill with air that fast--sounds like a bigger leak to me. ONe of the equipment experts should be by shortly to give you some useful info, but just wanted to welcome you to the forum!
    Welcome to the Forum!
    Air is going to be caused by a suction side issue - either a leaking line pulling air in or a problem at the skimmer, like the water level too low or the skimmer 'door' (weir) stuck in the up position.
    Do you see air in the pump basket?
    Give us enough info and a little time and we ought be able to help you determine the cause and then we'll help you firure out the best way to address the issue.
    Jun 2011
    Thanks, I appreciate the responses. I only see the occasional grain sized bubble swirling around in the pump basket. One thing I did find
    over the weekend is it only happens when I have the main drain line open and the skimmer line closed. When I open both lines the filter
    stays completely filled with water. Perhaps the is a leak in my main drain line then? The water level is fine, no air sucked into the skimmers,
    and the weirs are flapping like they should. I did order a new gasket for the pump lid, the current one is a a few years old and was rarely lubed.
    Thanks for the feedback!
    It sure sounds like a 'pin hole' leak in the MD line. I'd say it's something to keep an eye on, but not loose sleep over
  1. How often shoud I replace sand in sand filter?
    By mikef in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 10:41 PM
  2. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 08:36 AM
  3. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
    Last Post: 05-30-2007, 11:01 PM
  4. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 12:01 PM
  5. Jacuzzi ST-24 sand filter - sand in pool
    By ksturge in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 08:58 AM
