Re: cost
However, there are hidden costs too
for every 10 ppm FC added by trichlor you are also adding 6 ppm CYA so in a short time your stabilzier level is too hgh and you need to either add algaecide to prevent algae (works for a while) or do partial drain and refill to bring the CYA back down. Also, trichlor is very acidic so you will be needing to raise both pH and TA on a regular basis.
Cal Hypo adds 7 ppm calcium hardness for every 10 ppm FC added so you calcium will continue to rise. Whether this is a problem depends a lot on your fill water, how well you monitor and maintain your pH, and how stable your water temperature is. It is essentially pH neutral on use since it goes in alkaline but the reaction of chlorine as it sanitizes is acidic so your main pH adjustment will be a bit of acid from pH rise caused by outgassing of CO2. this can be minimized by adjusting TA downward.
Bleach really only adds salt to the water which has no negative effects. (If salt was a problem then salt water chlorine generators would not work.)
It is also pH neutal on use like cal hypo. If liquid chorine in refillable carboys is available in your area at the pool stores then it is often a better value than buying laundry bleach so check the prices. The pool chlorine is approx. twice as strong as the (6%) bleach so you need about half the amount for the same FC level. Iif it works out to be less than half the price per oz (or gallon) then it is a better buy. However, you often have to buy the carboys outright. Generally they are in the neighborhoold of $5 for the 2.5 gallon ones. After the initial purchase you then just pay for the chlorine (and no plastic jugs to recycle). If pool chlorine is not available in your area in the carboys then bleach is usually a better deal then the gallon jugs of 10% liquid pool shock.
