Thread: Clear water, but tough algae on rough spots
    Default Clear water, but tough algae on rough spots
    My plaster pool is eight years old and has some rough spots. I have algae that is growing in these rough spots and is a real pain to brush off. Using my normal pool brush on the pole doesn't do it - I have to use a hand brush and scrub, scrub, scrub. Of course, getting the spots below my arm reach takes many, many dives. It seems like I can never get it all. Any tips, or do I just have to keep working it? Shock it to 20 ppm Cl (it's 30K gallons, so that means tons of bleach)? Free Cl has been running around 5 and I have been adding poly, but that doesn't do anything for these spots.
    Apr 2011
    virginia
    Default Re: Clear water, but tough algae on rough spots
    Are you sure they're algae? Does your pool hold FC overnight?
    If no FC loss overnight, then fairly certain its not algae- FC kills algae day or night, but gets used up doing so...
    If it is algae, shocking is best way to get rid of it- get pool to shock level based on CYA level and hold it there til you pass overnight test (<1 FC drop between sunset and sunrise)
  1. Tough Algae even with high chlorine
    By Rvjames in forum Dealing with Algae & Slime
    Last Post: 07-04-2012, 11:58 AM
  2. Clear water but dark algae
    By cscgal in forum Dealing with Algae & Slime
    Last Post: 05-21-2012, 11:52 PM
  3. clear water before algae bloom
    By shub_31 in forum Dealing with Algae & Slime
    Last Post: 07-14-2011, 09:24 PM
  4. Clear water but algae growing
    By mortimay in forum Dealing with Algae & Slime
    Last Post: 06-25-2011, 10:35 AM
  5. Algae gone-water still not clear
    By karenkr in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-22-2006, 10:44 AM
