Thread: Power Washing an IG Pool???
    NJ
    Default Power Washing an IG Pool???
    I am opening my vinyl inground pool for the 1st time since I bought the house (6 yrs.). I called a pool co. & they told me they would drain the pool, while putting a vacuum behind the liner to keep it against the the wall. Then they would power wash the walls with algacide & water as the walls & water are really black & dirty.
    Is this an accepted method, to power wash a vinyl liner? The co. told me there is a 50/50 chance of the liner holding up, & made me sign a disclosure. Are they just trying to get me to put in a new liner?
    Please help.
    Honesdale PA
    Default Re: Power Washing an IG Pool???
    If the liner is 6 years old I wouldn't even think about even draining it let alone pressure washing it. I have no experience in this area at all and I'd wait for more inputs from those here with more experience before letting them touch it.
    haze_1956 is offline ** No working email address ** Thread Analyst haze_1956 0
    nj, usa.
    Just need a little clarification.
    You have owned the house for 6 years and the pool have been unused for that long?
    Or this is just the first year you are opening it yourself?
    NJ
    I owned the house for 6 yrs & never opened up the pool (hard to believe!).
    EricF is offline ** No working email address ** EricF 0
    Greenville, NC
    How much is the powerwashing vs. a new liner? After six years of algae, etc. in the pool, I wonder if they are not giving you an optimistic estimate of a 50% chance of a favorable outcome. I personally would use the money for a new liner, as I think it will be very difficult to drain the pool and remove the stains without causing significant damage. I have to admit, though, I have never heard of powerwashing a vinyl liner.
    EricF
    nj, usa.
    I think the first step is to check if the liner will even come clean.
    Try scrubbing a section a foot or so down and see if the crud comes off.
    If it does, then it might be worth trying to clear the water and see if you can brush the liner clean. A smaller investment before you commit to liner replacement.
  1. borax vs Arm and Hammer washing soda
    By joecus in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-01-2010, 03:10 PM
  2. Underwater Pressure Washing Gunite Pool
    By dbbarron in forum In-Ground Pool Construction and Repair
    Last Post: 05-22-2010, 03:56 PM
  3. Pool Opening VAC - VAC power goes to zero
    By sleater in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-30-2006, 10:48 PM
  4. Draining and acid washing to get rid of black algae
    By howbout in forum Dealing with Algae & Slime
    Last Post: 05-20-2006, 11:47 AM
  5. Need an idea for washing a leaf net
    By ChuckD in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-15-2006, 09:43 PM
