I discovered the pool contractor overlooked the overflow that was suppose to be installed in my in-ground pool. The pool has three returns. One return is to the Care Taker nozzles that are situationed on the floor of the pool. The second return is to two bubble jets (water mixed with air) and the third return is to a 3/4" nozzle on one wall of the pool.
To fix his mistake, the contractor capped the Jandi valve return port to the nozzle on the wall of the pool and retubed the nozzle tubing to a stand pipe that is cut off to allow water to flow from the nozzle to the stand pipe when the pool is more then 1" overfull.
The overflow system works fine but I miss having water flowing from the nozzle. I am trying to figure out how to have the nozzle work as a nozzle should and with the turn of a 3 way valve, stop the water flow to the nozzle and at the same time connect the nozzle to the overflo stand pipe. I really only need the overflow when we are on vactaion so only having one or the other at any given time is not a serious problem.
I figured an addtional Jandi 3 way valve would allow me to reconfigure the system so that I could have water flowing to the nozzle in one postion and in the other postion stop the water flow to the nozzle and at the same time connect the nozzle to the overflow pipe.
As far as I can establish, a Jandi 3 way valve will direct water to either of two ports that are 180 degrees apart but it will not stop the flow from the pump and connect the nozzle to the overflow stand pipe at the same time.
I know I could make it work by using simple quarter turn on/off valves is three different places but I was hoping to accomplish the change-over from water flowing to the nozzle to overflow water flowing from the nozzle to the overflow stand pipe by using one three way valve.
I have checked the Jandy web site and cannot find a valve that is designed to do what I need done.
Any and all ideas are welcome? Bill
