Results 1 to 10 of 22
Thread: My algae issues
    Default Re: My algae issues
    Post this new info about your multiport in that thread instead of this one. You're more likely to get equipment help there rather than here in this algae forum since some of our equipment people don't frequent this section as much as that one.
    May 2011
    My multiport issue is solved, so now I am just working on getting that "perfect" pool water. At the moment, the water is slightly hazy. I'm not sure that it even has any green hint to it. Here are the results from my morning testing:
    FC= 20
    CC= 0
    pH=7.2
    Alk= 85
    I know that the pH is a touch low. I have always had difficulty in maintaining a higher pH. it was a 6.8 yesterday, so I added some pH plus (had it left over from last season - next time I'll use the BBB method).
    Here are my questions:
    1) How do I maintain a more controlled pH?
    2) Do my readings indicate that my pool is safe to swim in? I'd really like to get in to vacuum it out.
    3) How do I go from being a "restricted user" to a regular one?
    Try bumping your alk up a little with some baking soda to maybe around 100 or 110. It may help make your pH more stable. Start with a lb. of baking soda and test after a few hours to see what that does for you. Then redose if needed.
    So that I don't have to reread this whole thread, please post your CYA reading.
    Regarding not being a restricted member anymore, the fastest way is to bump up to subscriber level.
    May 2011
    CYA level is 0.
    I just skimmed the thread again and found this statement that you made earlier:
    "Stabilizer...hard to tell, originally it looked to be less than 30 ppm, but later looked to be above 50 ppm"
    So, now you're saying it is 0? Have you added anything with CYA in it other than the 8-oz. bag you mentioned earlier? Any trichlor pucks? Any actual CYA bought separately? When was the last time you tested CYA?
    May 2011
    Those readings were with an old test kit and then with some old "dip and stick" checks. Once I received my K 2006 kit, I tested it and it was a zero. This was late last week.
    I have added another bag of shock and used a couple of trichloro pucks. I have not tested the CYA since late last week. It appears that I was 3 more CYA tests left in my kit.
    Since you have no CYA, or very little, it is ok to go ahead and use dichlor shock and trichlor pucks for awhile, but monitor the CYA level periodically or else you may end up with too much. Until you start to get some CYA built up in the water, you may have to add bleach morning and evening. Once you start to see a CYA reading, you'll be able to test and dose in the evenings only. You asked if you could swim with cl at 20 ---- that is pretty high but with little cya, it won't stay that high very long. it is probably ok to swim but I think I'd wait until it came down some if it were me, maybe to 10 and then I'd wear an old suit. You really don't want to take the cl that high as it may bleach out your liner. I wouldn't take it any higher than 10 right now. Keep filtering and hopefully the haze will soon be gone. You're almost there ...............
    EDIT to add: Dichlor adds 9 ppm for every 10 ppm FC added and trichlor adds 6 ppm for every 10 ppm FC.
  1. I'm having issues!
    By krissy in forum Pool Chemistry for Intex-type Pools
    Last Post: 05-17-2012, 08:18 AM
  2. Massive algae issues
    By Luke978 in forum Dealing with Algae & Slime
    Last Post: 05-03-2012, 10:24 PM
  3. Algae and now ph issues
    By ComeShareACupofTea in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-24-2011, 08:39 AM
  4. Help! Pool Cover Issues and Leak Issues
    By b2001 in forum Pool Equipment & Operations
    Last Post: 02-17-2008, 05:34 PM
  5. Help! Ph and swg issues
    By SoCalBoo in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-28-2006, 07:07 AM
