Glad it is looking better. Test early in the morning before much sun is on the pool. If you have lost no more than 1ppm over the reading taken this evening, then you have probably turned the corner and can let your chlorine drift down. With CYA of 90, you'll need to be sure to always keep your chlorine between 5-10 ALL the time or you'll risk another algae bloom. I hope you aren't using trichlor tabs or dichlor. With a CYA of 90, you don't want it any higher and both of those will add more CYA to your water. Glad to see you back around the forum this year!
