Results 1 to 10 of 13
Thread: Life of Sand Filter?
    Tennessee.
    Default Life of Sand Filter?
    I have a 24ft (round) AG pool.. Not sure of the sand filter size.. it came with the whole set up.
    Anyway.. do you think there is a normal life span for the sand filter? Mine is about 6 years old.. I run it all year. Much less in winter... but it is still in operation 12 months every year. Over the years the pressure guage has busted and is useless. Also I notice water comes out of the guage area when I backwash. The lever/handle on top works ok.. but seems a little loose.. and at times I have to mess with it a little to get it in just the right position.. or water dribbles out the backwash/waste port.. even when in "closed" or "filter" position.
    The filter seems to work ok.. and I am not concerned about having the pressure guage. I have pretty much "learned my pool".. and I can put my hand in front of the return and know when I need more or less pressure.
    Would my pool operation be anyh better with a new sand filter.. or do I need to spend that money on beer, instead?
    Swimming pool.. or camper? Swimming pool.. or camper? ...what the heck.. buy both.
    Jun 2010
    Default Re: Life of Sand Filter?
    Interesting thread. We are in the same boat! We've had ours 6 years as well. The gauge is busted as well, but like you, I know my pool and when to backwash, etc...
    My problem is this: Last year my husband changed the sand in the filter - he's done that before (we've been AG pool owners for over a decade), but for some reason something wasn't right and sand was being injected *into* the pool. Not much - you couldn't really *see* it or feel it coming out, but I knew it was there because it would settle on the bottom and was VERY difficult to clean up (maybe too heavy or dense to be be picked up by the vacuum well?)...drove me nuts all year!! So I asked him today to take it apart and see what's up - he responded that it's a pretty simply operation and he can't imagine what caused that and maybe we need a new filter? (I don't want to buy one if there's something we can do to fix this). Anyone else have this issue?
    What you are describing are not problems with the filter itself but with the multivalve, which is usually a repairable item.
    Gauges are usually easily replaced as long as its threaded nipple is a standard size. Shouldn't cost much.
    The leaking of the valve is most likely caused by a worn-out or damaged "spider gasket", a large rubber O-ring that looks like a spider web. There could be other problems with the multivalve, such as damaged springs or internal chamber walls.
    Tennessee.
    thanks CardD.. keeping in mind that I am not a pool expert.. and not a mechanic.. is this an easy repair? Can you point me towards a thread (maybe with pics) of what I might see when I remove those screws at the top,.. etc.
    Or.. is it really a repiar that I need not be too concerned about?
    OK, I'd let Poconos, aylad or WaterMom direct you on that--they are GREAT at such things--explaining it to the non-mechanical. Since I've only had my MV apart once, and that was years ago, I might lead you wrong (I'm very mechanical, and if I really know something, I can guide a beginner through the steps, but not if it's vague).
    At worst, you'll have to replace the MV, but I doubt that's necessary. What you WILL need is a replacement spider gasket for the make and model.
    You'll have to disconnect the MV from the pool's plumbing and remove it from the filter, making sure all the pool's drains and returns are plugged.
    If it was installed with quick-connect junctions, it's easy. If it's all glued in, it's tougher.
    SalemCastles Guest
    Sand getting into the pool is caused by a broken (cracked) lateral which could easily be done when changing the sand. Laterals are plastic mesh tubes in a spoked pattern that keep the sand in and let the water through. For my Hayward 22" it cost $80.00 CDN a few years ago.
    Glenn
  1. Sand Filter dumped all the sand in my pool
    By ib_gman in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-15-2012, 01:16 AM
  2. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 09:36 AM
  3. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
  4. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 01:01 PM
  5. Jacuzzi ST-24 sand filter - sand in pool
    By ksturge in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 09:58 AM
