Results 1 to 8 of 8
Thread: Skimmer clogged
    May 2011
    Default Skimmer clogged
    The 2 skimmer things on the sides of my pool are completely jammed with a hard, white substance. The skimmer drain isn't running at all and the only way i can get water to circulate through there is by turning the "Vac" setting on Instead of the skimmer (there are 2 pipes under the basket)
    What can i do to unclog the pipes? I can't just dig the stuff out it goes to far in...
    I'm sorry if this is a dumb question, i've never had a pool before and i can't find a pool guy IRL who can help me.
    Any advice would be much appreciated thank you!
    May 2011
    Default Re: Skimmer clogged
    I can try to take some pictures if that will help?
    Is it the skimmer basket or the skimmer pipes that are silted up?
    May 2011
    It's the pipes, there are 2 pipes below each basket, i can make 1 of the 2 pipes work by turning the "Skim" lever off and the "Vac" lever on but if I have the Vac on the Main Drain doesn't work....
    fog80 is offline Registered+ Thread Analyst fog80 0
    Columbia, Maryland, USA.
    I had a clog in my skimmer yesterday that I was able to free with a 25' snake that you would use to unclog any plumbing line inside your house.
  1. clogged pool filter
    By brutuszada in forum Pool Equipment & Operations
    Last Post: 07-11-2012, 12:22 AM
  2. 380 polaris jets clogged
    By lpops6 in forum Pool Cleaning: Manual or Automatic
    Last Post: 12-20-2011, 06:36 PM
  3. skimmer line is clogged
    By geebageeba in forum In-Ground Pool Construction and Repair
    Last Post: 09-08-2011, 07:32 AM
  4. Possible Clogged skimmer line
    By buki5 in forum Pool Equipment & Operations
    Last Post: 06-20-2010, 10:39 AM
  5. Help with clogged impeller
    By pool newby in forum Pool Equipment & Operations
    Last Post: 07-17-2006, 11:54 PM
