I have a 1 1/2 HP pentair pump that was working fine yesterday then today timer clicks and the pump motor is making a loud humming noise for about 30 seconds then it turns off. After a couple minutes it does it all over again. I took the motor off the pump assembly to check the impeller, but it spins freely. However, the motor casing was extremely hot. I tried to see if a 2X4 would help out the starter but it didn't do anything. Please help. thank you in advance.
