Thread: pool leaking a couple inches a day
    Default Re: pool leaking a couple inches a day
    I'm not the best at this but you first need to figure out if the pool is leaking or the plumbing is leaking. Look for there the water is building up. There's also a leak-finding dye for pools that you can try. You don't want to pay for repairs to the pool if it's the plumbing, and you don't want to go over all the plumbing if it's the pool.
    Welcome to the Forum!
    The bucket test is used to take evaporation out of the picture (mark the pools water level, fill a bucket with water and mark the bucket level and set it on a step - check the next day and see if the pool level has gone down more than the bucket level) - if the bucket looses less water than the pool, you've got a leak.
    The next step is to do a 'static test'. Plug all the lines going into and out of the pool while doing the bucket test. If the pool looses more water than the bucket - the pool vessel is leaking, if they loose the same amount, you've got a leak in the plumbing.
    If you have a leak in the plumbing, pressure test the lines to figure out which line is leaking. (there are ways to isolate which line is leaking but, I'll stop here for now - and be ready to answer any questions you have, when they arise)
    Thumbs up Re: pool leaking a couple inches a day
    Mom, (Lisa) I try to further what Ben started by helping folks not have to rely on, often unreliable, pool stores. I've learned so much here that the least I can do is share what I know with the good folks here.
    I appreciate your sticky-ing my advice and hope that you are well! (you know what I mean)
    [FWIW - when the other sites started popping up a few years ago, I joined them but always made it known that my first loyalty was here and, if I only had time to visit 1, PF would always be my first stop ]
    Love and Luck!!
    Ted
  1. Couple questions. 1st year of closing AG pool.
    By HollyClo in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-14-2011, 03:06 PM
  2. 10 inches of RAIN in pool, now what??
    By poolmom06 in forum General Interest
    Last Post: 07-05-2007, 03:31 PM
  3. 2.75 inches of rain in 2 hours--dirty pool!
    By azhobbs in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-26-2006, 08:24 PM
  4. liner has sunk 4 - 6 inches in deep end corner
    By mccaldd@insightbb.com in forum In-Ground Pool Construction and Repair
    Last Post: 06-30-2006, 06:40 PM
  5. New Pool Owner with a couple Questions
    By mrbadlands in forum In-Ground Pool Construction and Repair
    Last Post: 05-27-2006, 08:30 AM
