I wouldn't bother with cleaning the pool yet and especially not changing the sand. I'd just start adding bleach. You say that your Baq. level is at zero or close, but you may find out that you do still have a little more in there than you think. When you add the bleach, you'll find out. It may turn some funky shades of green. After you are able to hold a chlorine level overnight and the pool water remains clear, then is the time to change out the sand. Wait to vac until you see if your pool does turn green. No sense in wasting water. Keep us posted with progress.
