Ha!-Ha! Lisa's right. A pool store that doesn't know what Tri-Chlor is, isn't a pool store.
When you look a container of chlorine tablets or powder it will say on active ingredients Trichlor...something. That's Tri_chlor. If it says Dichlor...something...that's Di-Chlor. If it says Calcium Hypchlorite, that's Cal-Hypo.
Frequently Tri-Chlor tablets are labeled as Stablized Chlorine, but the ingredient is Trichlor...etc. If it says "Double-Acting" or contains copper do NOT,NOT buy it!
With a gunite pool you also need to watch your Calcium Hardness levels. You T/A as at the high end, or just past. If your T/A is too high and your calcium is too high, you'll get cloudy water.
For now, I wouldn't even add Borax to raise pH. Instead, I'd use aeration of the water, which will increase it. Doing that will keep your T/A from rising.
If you don't have tri-chlor or dichlor around, just use bleach and add CYA.
But most important is to watch your numbers.
