Results 1 to 8 of 8
Thread: Please help, green pool
    May 2011
    Canyon Lake, Texas
    Default Re: Please help, green pool
    I would also bump the chlorine up to 20 ppm, since the CYA has gotten so high Keeping it at 15 is walking a fine line between enough and not enough (see the Best Guess chart in Watermom's and my sigs)
    OK will do.
    Do you think that is all that i need to do for now?
    Thanks you guys for the help!
    -Micah
    Apr 2011
    virginia
    that should work for now- get the FC a little higher, and it should start clearing away...
  1. Replies: 8
    Last Post: 08-04-2012, 11:43 PM
  2. Green, green, green and running out of patience.
    By marciastz in forum Dealing with Algae & Slime
    Last Post: 06-12-2012, 12:51 PM
  3. green water or green liner?
    By denanbob in forum Dealing with Algae & Slime
    Last Post: 05-26-2011, 12:16 PM
  4. green pool: like black/green pool
    By bazman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-06-2010, 11:25 AM
  5. green green pool
    By mr greenpool in forum Dealing with Algae & Slime
    Last Post: 07-09-2006, 02:04 PM
